1 - 3 of 3 Posts
I'm using a Mallory 4302 adjustable fuel log, it regulates the pressure after carb. It had a port for fuel gauge located at the beginning of log right before the carb. The gauge shows 13 psi and doesn't change psi at all when I mess with the set screw that is sopposed to regulate the pressure. Is the thing not working right or am I missing something here? Correct me if I'm wrong but if the pressure was truly that high wouldn't fuel be overflowing into the carb?
Little bit more info, using Mallory comp140 pump -8 feed line and -8 return line.
1 - 3 of 3 Posts
