1 - 4 of 4 Posts
· Registered
Yes...you will need to up the size of the fuel jet...just depends on what fuel psi you run. I run a NX efi plate kit...I just called NX...got a E85 jet map for my plate from them.
· Registered
Thanks Jeff. Do you know kenny there in Independence,KY? Sorry cant remember his last name. He does powder coating. This is his old car in the profile pic. Wanting to try some nitrous on it.
· Registered
Yes...Kenny Mead...he's a friend of mine...helped him work on his old coupe/now your's a few times. That is a very nice coupe you now have. You may want to check out www.e85performance.net also...some good tech info can be found there.
1 - 4 of 4 Posts
