1.35-1.45, but the car is not set up for these tires, I just bolted them on and raced it. I usually 60' 1.25-1.28 at the same track on 10.25x28S ET drags.Kevin,
what kind of 60ft are you getting with the 28/11.5 QTP??
I think I could, I have the car set up really stiff in front to keep it off the bumper. Plus I'm at 55/45 F/R on weight. If I put 5% more on the rear and went to 275lb front springs instead of 300s and took the limiters off the front I bet I could get into the 1.2s, Naturally 60's times vary with different tracks, London Kentucky is about in the middle on 60 foots times around here.You think you could get that tire in the 1.29 - 1.30 range?
The class I am going to run has to run a 28/11.5 or smaller et street / qtp
They work pretty well for me, I'm at 3450 right now so I'm a little heavy..I noticed that about the QTP.. I am looking at putting on the 27/11.5 or maybe even the 27/10.5.
my weight will vary from 3200lbs to 2800lbs depending on the race.
How wide of a rim is everyone using on the true 8.5'sCRAIG WATSON IS ONE OF THE FASTEST I HAVE SEEN ON A TRUE 8.5 TIRE. I THINK HE HAS GONE SOME LOW 5.60'S AT 127MPH. ALOT OF US USED TO RUN UP AT US 60 RACEWAY. I DO KNOW THAT THEY ARE RUNNING SOME EVENTS AT I-40 DRAGWAY IN CROSSVILLE, TN. THE NORM IN THE CLASS IS 5.60-6.00 RANGE. PRETTY DAMN FAST ON A 26-8.5-15 SLICK!!!!!!
8-10" is the norm.How wide of a rim is everyone using on the true 8.5's
