1 - 2 of 2 Posts
I am not really how to explain this but i am trying to figure out how to put my distributor in so i get everthing lined up right not sure how the timing marks are on my innovators west balancer with a built in crank trigger i know it need to be put in between 60 and 130 degrees but i am not really sure on my balancer where 60 and 130 degrees is any help would be greatly appreciated and if you need more info let me know and i will try to give it the best i can
Find the TDC marks. The damper is marked every 5 degrees with the short marks, 10 degrees with the medium length marks and 90 degrees with the long marks. The damper should be stamped on the 30,40 and 50 lines for reference. Turn the motor to 60* BTDC and drop the distributor in with the rotor lined up with the #1 terminal. Then you can move on to setting the cam sync (if adjustable).
Chris
1 - 2 of 2 Posts
