:-D Oh, You know. :-DHow did I know that you would be the first person to reply to this thread????? LOL.
What brand and model saw is it and how long of bar is on it?if so what did you do to get some more hp out of it??
LOL i love the bullet. Always an answer on hand.I have been a timber faller for 20 years and all I run are modified saws. What do you have?
homelite 23av think it is 16 inch bar, it was free......I have been a timber faller for 20 years and all I run are modified saws. What do you have?
Add another port to the muffler, on the inside there is a "flame Box" that blocks exhaust directly out of the port. Drill several holes in that also. Remove the base gasket from the cylinder and true the cylinder base and install without the gasket,loctite the bolts though. If you can open up the airbox also.homelite 23av think it is 16 inch bar, it was free......
I just want to tweek it a lil bit. Base gasket? would I need to jet up?Add another port to the muffler, on the inside there is a "flame Box" that blocks exhaust directly out of the port. Drill several holes in that also. Remove the base gasket from the cylinder and true the cylinder base and install without the gasket,loctite the bolts though. If you can open up the airbox also.
If you want to get advanced with it port the intake side of the piston and cylinder and open up the exhaust port too.
The gasket between cylinder and case.I just want to tweek it a lil bit. Base gasket? would I need to jet up?
Thanks!The gasket between cylinder and case.
Jetting should be fine just adjust tuning screws to richen it up.
any quick mods for a stihl ms 290What brand and model saw is it and how long of bar is on it?
I modify saws different per application.
No problem. Keep me posted how it goes and hit me up if you have any questions.Thanks!
Basically the same thing. Open up the exhaust so it can breathe. I like to buy an exhaust port and screen for a Husky 288XP. They work awesome and have a spark arrestor screen also. Drill out the flame box and mod the raincover for the filter to get more air in also.any quick mods for a stihl ms 290
