I see a lot on the gen1 4.3. I'm struggling to find the ls version.I think Richard Holdner on YouTube has? How much boost does it need to get the job done?
be safe, schick
Seems like at 295hp stock. If it has the LS components, at 15 psi it would be safely making 600 ish in OEM configuration.I had not seen those articles. Scoggen Dickey is now offering a 4.3 for boost applications in the 600 hp range.
I see they deleted it on their dyno tests. They do have a sound......kind of a bad one. LOL.The LV3 is Gen 5 (LT) based and is a Direct Injection engine.
I have been following this engine for a while and I am glad to see that Scoggin Dickey is working on parts for them.
I would love to find another junker C4 Corvette and turbo one of these LV3s. Seems like their would be ample room for everything with it being so much shorter.
What I have read in the past year is that they are limited to mid 400s at the wheel with boost because of the high pressure pump limitations. I believe SD is working on a port injection manifold but I haven't seen any updates or anything else on it in the past 6+ months. I read that the other Gen 5 high pressure pumps don't fit but I really have no idea about that.
I find the new LB3 2.7 turbo engine to be fascinating too but that was until I read they are on 22+ lbs of boost stock to make their numbers. So I don't know how much more you could squeeze out of them. But heck, lots of guys pounding little 4 bangers with 40-50+ psi and the LB3 is an all forged rotating assembly I believe.
