1 - 19 of 19 Posts
I have them on my 632. No problems here. Although the motor seems to be down on power but that could be due to anything.
SOFA KING WHAT?
Al Marlow is using a set of BMF's on his X275 Camaro (they maybe the 405's) has run 4.81 on 275's.
have set of 350 makes good power but had leak behind exhaust valve we fixed em but no other problems
Have a set of 385's on a 598 bracket style build. 125+ plus runs a year, cam around .800 lift, single carb, stud rockers, and super vic. Has gone 181MPH at 2550 punds on a single .028 jet. There alright but there are better choices now if buying new. And they flow no where close to as advertised.
TD 3550
Running the 385's on the 598. Stud rockers. Cam is 800/782 284/304. Saturday i just straightened the Geometry out. Went to Harland Sharp wide bodies 1.7 With Stock OEM guide plates The OEM guide plates straightened everything right up Best ET 7.44 @179 on Q fuel. Carb is spec from Prosystems.
1 - 19 of 19 Posts
