The class I race in has new rules that allow SB's a 82N jet and BB's a 70N jet. Also a -4 line.
I normally run lower pressures on the nitrous side 850-900. When you run higher pressures do you actually get more flow? And what is the highest nitrous pressure you can run if it does help.
I know at higher pressures it tends to damage plungers.
Thanks for your input!
