I need a clutch kit for a 2009 Sentra Spec V 2.5L
Is this factory?398.95 with slave cyl
Yea... built in napa's factoryIs this factory?
napa only shows it in Washington state they have 5Yea... built in napa's factory
Me too..... If the Phucker comes back...Get a part # and I might be able to help on OEM...![]()
About $325.00 plus shipping [probably $25.00]... This is OEM Nissan..The kit is for me, I work here with Keith. I'm needing to get it done as soon as I can, as soon as I get a new kit in me and a buddy are going to do the swap. Only thing I found was my local NAPA said they could get an OEM for almost $500. Am really hoping for less. Thanks
Yes, on the parts... I dare say you'd have to replace the flywheel, but I can get a price on that too.. In most cases, they surface cut [machine] the flywheel...That's clutch plate, pressure plate, throw out bearing? Do you know what the flywheel would cost? I called the Nissan dealer and they said like $1k just for the flywheel. I'm hoping mine isn't warped. I sent keith the message to call you.
