I have an older Tial 44mm WG and I was wondering if anyone has a pic of where they drilled/tapped to add a dome pressure sensor.
Thanks in advance
matt
Thanks in advance
matt
This.Easiest way is to just remove the dome/cap and find the thickest area for tapping/threading and will not be in the way of the spring perch. Doesn't really matter other than that.
X2....this setup is not the best. can wind up constantly chasing its tail so to speak. better off having the sensor in a seperate port so the wastegate volume acts as a buffer.
Wondering the same.Why 2 sensors?
X3.....Wondering the same.
