1 - 8 of 8 Posts
Here's what I put in my buddy Ricks stang
i used the team z motorsports kit when i did the mini tub
if you dont want to cut out the floor upr makes a coil over kit that mounts in the stock place of the shocks
Discussion Starter · #7 ·
im mini tubing to fit a 325/50/15 drag radial. just put in my anti roll bar, and its kind of a tight fit to put the coilovers in.
you will have to at least cut some of the tire well out our notch it for the tube to pass throw to put your crossmember to the rear of the shock.if you put it to the front it hits the anti roll.
1 - 8 of 8 Posts
