1 - 20 of 58 Posts
Was just diagnosed with sleep apnea last week and picked up my CPAP machine yesterday so last night was my first night wearing it and wondering how long before I get used to wearing it at night? The lady who did my orientation with it said I should be good in a day or two. It seems pretty unnatural to try and sleep with that on.
I have been using on for almost 3 years now.
It took me a good few weeks to get used to it.
Honestly sleep is a whole lot more productive and restful using it. As long as i have access to 110volt power i take it wherever i go when not home as well.
I use what they call full face ( covers nose and mouth ).
Stick with it and force yourself to wear it , sleep without it once and a while either unintentionally or when tent camping far from power, and i will feel the difference.
The machine & treatment saved my life. I am so much more healthy
because of it. Wear it every night, all night for the last 7 years.
Can't imagine living without it. How long to get use to it? Truly, never.
It does get better. Just resign yourself to the fact that you are going
to wear it!
They SUCK!! But as mentioned above, they really help sleep be better. Ive been using one for 9 years and still hate that damn mask.
I have been using one for a little over 4 years. It takes a little while. In the beginning I had a hard time waking up. Felt like I was in a sleep chamber.
Been on a CPAP for 12 years and I sleep like a baby for 7+ hours a night........ Took a few weeks to get use to but I can’t live without it now. 😴
The "trick" is to find a mask and head gear that is "comfortable"........ If there is such a thing.
Discussion Starter · #7 ·
They started me off on a full face mask because I am normally a side/belly sleeper and I couldn't get comfortable at all on my back last night.
I seems like I am breathing deeper with it on but the exhaling part seems odd to me.
My former wife used to complain that I snored. I mentioned it to my doctor, and he prescribed a sleep test. I had mild sleep apnea, 6.2 events per hour IIRC. The doctor prescribed a CPAP, and the company called me immediately to get one into my hands. There was NO WAY that I was going to sleep with that thing strapped to my head, especially since I sleep on my side, and can't sleep on my back. I declined their machine.
As an engineer, I looked at the problem as an engineer. Why try to force air down the airway, when it must be blocked. If you've ever taken a CPR class, they teach you to open up the airways. Your dentist can create a Mandible Relocating Device, at the cost of $1000-$1200. It's basically two football mouth guards, top and bottom. Amazon has them for, at the time, $50, so it was worth trying. Works GREAT. I sleep much better, and have had two confirmations that I don't snore any more. The price has dropped, and if you order one, they will send you an extra one. There are some that are a bit cheaper, but they are knock-offs. I prefer to reward the guy that came up with the original design. If I forget to put it in, I wake up a few hours later with a dry mouth.
This comes with my highest recommendation, which I don't give out very often.
Took me about 2 months to get used to a nose mask. It really helped me avoid sinus infections and sore throat from snoring and dry mouth.
Me too... I use a Dreamworks Nasal Pillow style mask... once accustomed to it, you'll barely be aware you have it in place.
I also believe there might be some advantage to breathing the semi-filtered air from the CPAP compressor... no doubt it has helped me in several different aspects regarding my sleeping process.
mardyn
Discussion Starter · #13 ·
I hadn't thought about sinus infections. I normally get a couple a year when the seasons change.
I used to get them every 45-60 days and live on antibiotics. Allergy shots and the CPAP were life changing in that regard. Now I get them once or twice a year when allergies are at their peak.
Can you sleep on your side and constantly search for a cooler spot on the pillow, or do you have to lay still on your back? Thx.
I’ve been using one for 5+ years. I’ll never get used to it. I’ve tried every mask they make. I sleep far better without it, alas I’m stuck with it thanks to D.O.T. regulations. I wish I had never saw it.
I have the nostril pillow type. Took about a week to get adjusted to it and love it. Been over a year now. Rest and sleep are great for me.
1 - 20 of 58 Posts
