I bought an S & W anti roll bar kit when I purchased the back half kit for my wagon 4 1/2 yrs ago. The axle/shaft that the aluminum arms attach to (see pic) pivots inside the tubing using poly bushings instead of needle bearings like some other kits have. I'm afraid the poly bushings might cause the shaft to bind and not move as freely as it would if it had needle bearings. I hope I'm not confusing the hell outta y'all. Do any of you guys use the S & W kit? Does it work well? How consistent are your 60 ft times? Does the suspension bind any? I'm thinking of buying another brand.
