I'm looking for ET guesses on MOTOR and SPRAY. Went from SBC to BBC, got a little bit of work left. Meanwhile want to see what you guys think it'll go. Thanks in advance
496 BBC, 4 bolt studded mains/short filled
14.1 JE Nitrous pistons (undecided on rings)
6.385" Rods
4.25" crank
Brodix BB2 heads, has Manley nextek springs.
Bullet RECCOMENDED .797/.775 lift (with 1.7 rocker) - 283/298 duration @ .050 - 112 LSA/108 ICL - 4/7 Swap
EndureX roller lifters
Victor 454r intake matched to heads
Carb is going to be a 4150
2-1/4 headers with mufflers
Powerglide with 1.76 gears, 12 bolt with 4:33 gears, 28x9 slicks. 8" converter, will be around 4XXX stall (have to send it off)
3200lb G-body, footbrake - 1/4mi car.
It has a NX Gemini kit, so I plan on spraying 250 shot or so.
6.385" Rods
4.25" crank
