1 - 5 of 5 Posts
i'm putting a plow on my 2006 f350 and i am looking for a good place to pick up "ignition on" power from inside the cab to power the controller. i went into the fuse box but all of the fuses appear to stay hot with the ignition off, even ones like the radio and others that i know shut down with the key. any suggestions? thanks
That is what i was thinking also.Left side under the dash by the kick panel there should be 4 blunt cut wires that are colored like the brake controler wiring.One of them should be key on power.Either the red or white one.
1 - 5 of 5 Posts
