1 - 3 of 3 Posts
How many of you guys running F1R setups do not have a crank support? Procharger says you dont need one, just curious how many run without with no problems.
Are you using a cog belt and running a limited tire? If tire slip isn't normally a problem you shouldn't need one. If you're on and off the throttle occasionally during a pass you would be better off to have one. If you run a serpentine belt you don't need one.
Im running a cog belt with a big tire, 31 x 18.5 Hoosier, so i dont think tire spin will be an issue.
1 - 3 of 3 Posts
