Main cap ground crooked,didn’t square up the cap? Converter charge pressure restrictor?
I've seen this issue/topic come up here on this board before, and it sure sounds scary to me, so I'm all ears so to speak. I'm very curious about something you stated above^^^ ....what made you decide to start going tighter than the .187" you used to use? You say that you have a Meziere flex plate? I just sold one of them, because I decided to use an ATI racing one instead. It looked to me that the Meziere F/P was made more rigid and solid than the F/P I have from ATI racing, and ATI says that this is a bad thing, because a "Flex" plate is supposed to flex. And some aftermarket ones appear to be made so rigid that they might not flex too easy. Not meaning to be a wise guy here. I'm merely trying to learn from what just happened to you at the track, and maybe in some small way bring up things that might be of help..
So I just had an engine lock up on the track during the 2nd pass
and at first they blamed me for being too tight without even asking what I set it up at.
It's the good Meziere and a good Neal Chance.
So not cheap junk.
It's at .140 exactly.
I was a .187 guy for decades and started going a little tighter a few years ago.
After the trans guy took apart the trans he said it's absolutely perfect.
So now the trans guy wants me to go even tighter.
He wants .090.
If I just chewed up a crank at .140, what will happen if I go even tighter??
What besides the converter banging into the crank can knock the thrust out of a brand new engine??
I have never noticed who mentions what to check, but I know that I always check both ends (pump pullout and pilot to crank interference). If not you’re just flying blind.To my knowledge, (which is limited) neither do the torque converter manufactures, nor the transmissions manufactures make mention of that^ either.
Please disregard what I said in post #13...I was wrong.....Rossler mentions the same thing that you did about the pilot engagement. Thanks.I have never noticed who mentions what to check, but I know that I always check both ends (pump pullout and pilot to crank interference). If not you’re just flying blind.
MR I was always lucky enough to have a local guy that would chuck up a piece of steel bar and have me some made to exact thickness in about 30 minutes or less..
I have three different brands of grade 8 washers,
2 gold that are way different and purple that is in between.
I also have some standard washers that are very thick and very thin.
So between those 5, I can usually get what I want.
I also have a big ass welding table with a 1" top that I can fine tune the washers if needed.
Like I always say, I am NOT a mechanic, never claim to be, but I can get the spacing right.
I knew I didn't blow up the new engine, but when the so-called experts tell you setting up the spacing is the only thing that causes the thrust getting knocked out.
You start to doubt yourself!!!
Mr. dragster, Way back in 1978 I was building a 302 cu. in. SBC to run C/SM in NHRA. Yea, I never had a chance, but didn't know any better. Well, when finished, put in the car started it, ran great. Ran for awhile in the driveway, didn't go to the track yet.
Let it cool, checked everything. Oil had very small amount of moisture, so I drained the oil, clearly bearing material in oil. Took it out and apart. Thrust bearing tore up. All the clearances were checked when I assembled it ,had new crank, aluminum rods, good pistons, etc. checked main saddles, all good, except the thrust. After doing this 3 times with same results, the machinist had me bring everything to them, said I had to be doing something wrong. Got it back, absolutely nothing could be found. This time, I put in car, left transmission out, 4 speed Doug Nash Pro Shifted deal, since machinist thought the input shaft was pushing the crank forward. Started it again, ran for awhile, drained the oil, more metal. Took it all back apart, same torn up thrust bearing, brought everything back to machine shop. Re-checked everything, nothing could be found. Shop owner, in frustration, called TRW, which was the manufacturer of the rod and main bearings back then, with all our clearance notes, come to find out TRW had problems with their bearings "flaking" in the thrust area only. They offered to replace the main bearing set only after much heated discussion.
So, I've learned to "Lower My Expectation, So I Won't Be Disappointed". regarding the quality of parts, even in racing.
