1 - 20 of 255 Posts
Administrator
With some friendly competition between the two company’s maybe we’ll see those Coyote powered pro mods get more competitive with the big motors
https://bangshift.com/bangshift1320/bangshift1320-drag-racing-new-products/accufab-announces-new-billet-coyote-blocks-available-soon-order-yours-now/
Why are billet blocks needed? I was told by the Ford loyalist (including you) that the stock blocks can handle unlimited power..
Just like Ford.. always copying Chevy...
BTW Andy Jensen said bring them!! :cool::cool:
Don't forget they have also said when it becomes a billet block it stops being a Chevy.
Pontiac "big block"
They said the same thing about cast aluminum Pontiac blocks.
If a cast block based 100% off the original is no longer considered a Pontiac, a billet block cannot be considered a Ford.
Discussion Starter #12
I guess if you wanna run faster than 5.8 then they are.:smt052
Discussion Starter #13
What if the engine still has a production cylinder head on it??
Discussion Starter #14
When it’s a billet block/billet head then it’s not a Ford anymore. :p
Son of Mr. David-get it ?
Everybody copies everybody on everything.
It will forever be that way.
Every which way you can, every time....
I wonder what Andy would run with twins, 3 extra cams and 16 extra valves on a SBC!!!! Bahahahahahah
https://www.youtube.com/watch?v=nBbP61javxs
How big is his motor again? I don’t see that car running a 5.80 @256 iirc with less than 400” I’m sure it would run close to the same ET if it had the extra cams, valves, and same displacement. I’d like to see what those mmr cars would run with a coyote the was the same displacement as Andy’s motor.
Administrator
It's 427 CID.. with a single turbo.. ;)
427”, huge single, aftermarket everything, at 2150lb minimum. Vs 351”, smaller turbos, and factory head castings, at 2350lb minimum. Would be a very close race if they weighed the same.
Maybe he should throw 200lbs of ballast in that car and see how it does compared to mmr’s cars.
Yellowbullet Overlord
Why don’t the MMR cars ever show up at a rade?
1 - 20 of 255 Posts
