CAN YOU USE THE OLD STYLE SOLID LINKAGE TO SELECT BETWEEN THE GEARS?....IS THERE A BRACKET FOR THE TRANS?....OR DO YOU HAVE TO SWITCH OVER?.;....I'M MISSING THE BRACKET FOR THE SELECTOR ON THE TRANS.....AND TRYING TO FIGURE OUT WHICH ROUTE TO TAKE....I'D RATHER KEEP THE COLUMN SHIFTER IF POSSIBLE...THANKS
