1 - 4 of 4 Posts
I have the spec book but nowhere in it does it say how far you can lean the main hoop back...I know 25.5 is max 20 degrees. I only need about 3-4 degrees for it to look good esthetically but nowhere in the spec does it say whether you can lean it back or not.
Paul
good question, I was also wondering that, I was just going to do it because it doesnt say you can't, I only need like 5 degree's
7.86 @ 8800DA 3365lb 275s
just had one certed that was laid back. 3-4 degrees wouldn't matter in any event. what are they gonna do make you level the car and check that it's perendiculer? even if the did what are they gonna reference it to? the rocker bars? rocker panels? or just to the ground when it's sitting at ride height? then what if the ride height changes in the front or back? hmmmm not being a smart ass just wondering too.
FUCKING ASSHOLE SINCE '61
Bumper scrapin' wheelstand..............whatca' gonna do then??
Just make sure the main bar is AHEAD of the drivers helmet all buttoned in.
Your Pal, Gary
1 - 4 of 4 Posts
