Is anyone here a dealer?
Has anyone used there Twin cam gear drives?
Im looking to do a set of cams and a gear drive set up on a twin cam 88.. I had a cam bearing failure that took out the whole engine,I found a replacement engine and trans at a steal..I installed it and got it running but was nervous because of the recent engine failure so i took the cam cover off and sure enough one of the cam chain tensioner paws in the new engine has a crack in [email protected] miles so i feel lucky i caught it as this is a common problem on these .
I have decided to just get rid of the tensioner set up and put Upgraded cams,gears and bearings in
