1 - 4 of 4 Posts
I just recently bought a AMS1000 boost controller and had a question.
If set my launch PSI at 8psi then set the second stage to 15psi at rate of 7.5 psi/second over two seconds.....will the boost drop below the 8psi launch then climb to the 15 psi in two seconds or will it continue to climb to 15 PSI from the 8 psi over two seconds.
I hope this isn't too confusing because I confused myself typing it.
If you set the launch psi at 8 then you will apply 8psi to the top of the gate when the tb is pressed. When you release the tb it will then go off stage 1 settings and so on. If stage one is 15psi over 2 seconds the pressure to the top of the gate will not drop down below launch boost. It starts from there and goes up.
Now, if you set the 1st stage to 5psi then it will drop down below launch boost.
1 - 4 of 4 Posts
