Switching between modes of operation
1—Set Stage1 and Stage2 programming switches to 0. Set Stage2 Ramp Rate select
switch to 1.
2—Turn AMS-500 on, the Stage1 Green LED will blink .
To change Stage1 operating mode you must wait 10 seconds with the Red LED blinking.
3—After 10 seconds the AMS-500 will automatically switch Stage1 operating modes.
The new operating mode selected will be indicated by flashing the either the Stage or Stage2
Green LED.
Use the guide below to determine the current Stage1 Mode selected.
Normal Mode—Stage2 Green LED will blink 5 times per second.
Launch Mode—Stage1 Green LED will blink 5 times per second.
Dual Stage Mode—Stage1&2 Green LED’s will blink 5 times per second.
TO TOGGLE THRU THE MODES JUST POWER OFF AND BACK ON AGAIN WITH TH ESWITCHES IN THE ABOVE POSITIONS.
4—Turn power off, set switches for desired target psi and ramp rate for Stage2.
5—Turn power back on and AMS-500 is ready to operate in selected mode.
So repeat this cycle as per the instructions until the led is binking what signifies the mode its in. In your case you will want the stg 1 led to be the only thing blinking. Once you have that set just turn the unit off and set your target pressures etc. It will remain in this mode until your repeat the set up and have the thing cycle thru its operating modes.Last mode its in when powered down is the mode it will be in .
