61 - 80 of 286 Posts
Cam the new valve be retro fitted to the AMS-1000?
Discussion Starter #73
Offered in 2 platforms
Basic-
Features 10 control strategies and 6 predefined datalogging channels and overlay capability. Auxillary Channel Control, Gmeter, and Offset capability that are available in the PRO unit can be enabled at a later date. All laptop based.
No Selector Switch(Can be purchased Separately).
What does it come with?
Control Unit, 100 psi sensor, solenoid system, harness and manual.
Datalogging:
6 Channels(Target Pressure, Boost Pressure, Battery Voltage, Target Actual Pressure, Profile Voltage, Boost Control State Timer)
10 Control Strategies:
Time Based
Shift
Variable Voltage(Ex. Gear Position Sensor)
Engine Rpm
TPS
Air Fuel
Pressure( Ex. Back Pressure)
Shaft Rpm ( Turbo Speed, DriveShaft Rpm, Any RPM signal)
MPH/ SPEED
Air Temp
* The Basic Unit does not allow any offset capability and no Aux Channel.
PRO-
The AMS-2000 PRO offers 10 control strategies and 36 datalogged items and overlay capability. 2 Controllers in one unit(boost channel and Auxillary channel), Datalogger, G-Meter(lateral and longitudal), 5 position selector switch . All laptop based
Control Unit, 100 psi sensor, 5 position remote switch, solenoid system, harness and manual.
Internal 2 Axis Accelerometer:
Lateral and Longitudal Acceleration up to 3 G's recorded in datalogger
5 Position Selector Switch:
5 tunes tied to this switch for instant map changes without a laptop
Datalogging:
36 items being logged at 100 hz. Everything that would come in a standard Datalogger you have here and more! A few listed below:
TPS
Engine RPM
Air temp
Drive shaft rpm, turbo speed or any rpm source
MPH
Aux Channel sensor input( any pressure source)
Pressure(any pressure source)
Variable voltage 0-5 volt( pressure, shock, ride height ec)
2 air fuel channels 0-5 volt
2 axis accelerometer 3g
Transbrake input/ clutch input
Shift input, Scramble and Reduce inputs can be used as event markers
2 auxillary output event markers
Battery voltage
Aux Channel:
Second Control Unit to handle alternate pressure control duty
If not used for Control it can be used as 2 programmable outputs(shift light etc)with programmable thresholds
Time Based
Shift
Engine Rpm
TPS
Air Fuel
MPH/ SPEED
Air Temp
Great news Seb. Can't wait to try this out.
I just got my 2000 in yesterday, all I can say is wow ,this thing awesome. Easy installation in just a couple hours, it has almost infinite adjustment to really flatten your graph out. and many ,many other features I have yet to tap into.I cant wait to get out and test this weekend
Hello all. Got my AMS2000 a few days ago here in FLorida. Excellent craftsmanship, packaging, and detailed instructions. Will be installing & testing very shortly. Thanks Sebastian & NLR !!!
