1 - 4 of 4 Posts
· Registered
Just got my AMS1000 wired up and took it the track last night and had a couple of questions.
The spring in my wastegate is good for about 4psi so if I put 4lbs of CO2 on top of the gate I should get 8psi..right or this just a rule of thumb? The reason I ask is I put 25 lbs of CO2 on the gate and only netted 18 psi....just curious if have some other issue or is that norm...checked everything and the wastegates do not appear to be leaking.
Also is there anyone that would be willing to share with the stage setups they run in their controller...I am on 28x10.5 tires 3400lbs twin 80mm.
thanks
· Registered
keep in miond that putting a number like 20 in the controller doesnt mean 20 lbs...you have to figure out what the numbers mean for your car...
· Registered
Back pressure in the exhaust plays a big role in your end boost number
1 - 4 of 4 Posts
