1 - 3 of 3 Posts
what is your guys' opinion of running these? my builder brought it up last night while i talked to him on the phone and said it would probably be a good idea. i just wanna know the pros and cons to them. how much lif would i get out of them running on the street once in a while? aren't they easier on parts as well? i really don't know jack about aluminum rods cuase i always thought they were too cool for me to run ha ha.
here is my combe so far.
408sbc
splayed mains/ half filled
13.5:1
was planning on 6" h beam (do i have to run a shorter one??)
aluminum heads
solid roller
dominator
blah blah blah
with 200-250 shot in mind, maybe more.
thanks
Administrator
Aluminum rods can be your friend and your enemy. Rod life isn't as great as it is with steel rods. You can expect 60-200 runs on a set without failure. It depends on how you are using them. You should, with the combo listed above, see 200 runs from a set. After that I would replace them. Big drawback on an aluminum rod is there is no way to really check them before they give. The up side is they are lighter, will take a lot more nitrous than steel rods and easier on bearings. I would recommend a set of Groden or Bill Miller rods for your motor... As far as street driving? Not really sure...
hey thanks. i think i'm going to stick with a steel rod now. i got 18* heads just barely and i don't want to over power or stress the stock block (ya its a stock 400 with that stuff done) i'm not going to spray i don't think. not worth destroying an engine to go a little faster. besides with a aluminum rod i have to clearance my block a little more and i need it to be as strong as it can get.
if/when i get a bow tie or dart block i'll throw aluminum rods in it.
thanks though
1 - 3 of 3 Posts
