what is the general expansion of a GRP aluminum rods is it .010 or what ?
perfect answer!Heat one up in boiling water and measure it.
That is twice you've mentioned "zero" and posted a link to that article?!?perfect answer!
I've ran both GRP and MGP's at zero.
My bracket engine is at -.005.
zero deck. he asked if you should run 10 in the hole.That is twice you've mentioned "zero" and posted a link to that article?!?
If you mean zero deck, that is no help without knowing total distance.
What stoke and rpm was that?!?zero deck. he asked if you should run 10 in the hole.
I've run zero deck and 41 total.
One was 3.00, one was 3.250, one was 3.750What stoke and rpm was that?!?
Thanks Chad this is just what I needed good info.
4.00 stroke and 7500.What stoke and rpm was that?!?
Crazy.................. But I see it works for you!We run .005 more room for the aluminum between steel and aluminum.....
that is the number it takes to let the piston just touch the head at the finish line on both type of rods
5.1 bore at 10200 RPM
Whew, you actually knocking the carbon off the chamber!We run .005 more room for the aluminum between steel and aluminum.....
So, if a piston is .003" off the head it'll be a turd?LOL! Had an older gentleman (engine builder) tell me if the piston don't touch the head it ain't making power.
