1 - 3 of 3 Posts
i am most likely going to be changing my gears/center section in my 3rd gen camaro (weighs approx 3500 lbs) and it has a ford 9 inch and 625 rwhp.
i have a iron center section now and the car is approx 80% street 20% strip would an aluminum one be ok or not?
I have an aluminum bolt though no problems at 3400lbs. Unless you are weight concious the iron will do you fine. No advantage going aluminum execpt for weight.
1 - 3 of 3 Posts
