Garbage......not going to expand enough to change the chamber volume
and I bet aluminum blocks don't grow either...
a good running comp or PS motor today if you used your theory...you would have one hell of a rod bearing bill at the end of the year!
i agree..HIS simple question is will you lose compression when hot
Yes, you may, BUT IT IS MINIMAL.....
DIDn't ask if compression goes up from cutting the head....
Think about piston dome growth the same way as they head.
would it not grow also??....i think SO
of course the piston grows...but the majority of the mass is horizontal not vertical. If the deck is ..250" you would expect a .002 growth max vertically.HIS simple question is will you lose compression when hot
Oil hot, block coldreher morris had an article on preheating a dragrace engine before a run.His determination was that this was counter productive because all of the engines they tested made more H.P. dead cold and if built and tuned properly has no affect on the longetivity.I wonder if outside of the obvious cooler denser air charge if there could be other factors like this discussion that may occur and also lower hot engine power.Not taking sides just wondering if it may be true
If that theory was correct.... why would you heat an aluminum head up to insert a seat? Wouldn't the seat press increase if everything was "growing"?I think you may have a point...
If the rocker bar on the top of the head, grows providing more clearance for lash... then it is reasonable to consider that on the other side of the head, the same condition is occuring.... the expansion always moves outward.... I think people are forgetting that outward, is all 4 sides of the head.... not just on top.
That being said, the deck is also growing..... eliminating the premise that the chamber is moving toward the piston.
In the end, I say there is no change in compression.
