1 - 4 of 4 Posts
Any builders using the th400 aluminum forward drum with the steel center hub ? Any stronger than the ones without the steel center hub?
I think the idea of it just makes sense. Added strength for the splines plus I would think it would have reduced ring wear.
There are a few choices like that now. If your not worried about every ounce of weight loss , you won't see a gain from weight savings with this part.
Hutch
1 - 4 of 4 Posts
