If your using a trans-brake valve body, you will need to use the trans-brake release springs and yes, the bleed hole will have to be drilled if the the drum doesn't have the trans-brake bleed hole . Also this is it usually how it works, a drum with check ball, no check ball in the piston, drum with no check ball, use a piston with check ball. Hope this helps. BurtI just picked an aluminum direct drum for my th400 and noticed a check ball in the drum behind the piston. Am right in assuming I dont have to drill a .060 bleed hole in this drum?
Think you have this back words.....helps the apply piston,When the gear is releasing when the fluid pressure is released from that gear, it aids in disengagement. When you tear down serveral different years, we noticed that the check ball will either be in the drum without one in the piston, or not one in the drum but it will be in the piston.
So I should plug the checkball in the piston since I have a checkball in the drum and drill the .060 hole in the drum. It is a transbrake valvebody btw.
Now that I thought about it, it makes sense. Bleeds the air out before fluid lockup. Never really thought about it until now, this is why I drill a 1/16" hole at the top of the reverse piston of a Glide, to provide a air bleed. Thanks! BurtThink you have this back words.....helps the apply piston,
keeps the piston from air locking while trying to apply
if it were the other way around you sure wouldn't need that there
.060 bleed hole, that bleed hole is recommended on all manual valvebody trans also, as it keeps the residual oil in the drum from appling the clutches in anything other than high gear.
hope this helps
Have you ever seen a drum with more than 1 check capsule? I have seen a drum with 6 , so should I plug 5? Don't get confused with OEM applications , this is a race trans with constant system pressure.
Hutch
Well, I was wondering why having the extra checkball would hurt. I have just never seen a th400 direct drum with the checkball, thought it was odd this drum had it. this is my first aluminum th400 drum to deal with. You guys have been great help, thanks to all.Have you ever seen a drum with more than 1 check capsule? I have seen a drum with 6 , so should I plug 5? Don't get confused with OEM applications , this is a race trans with constant system pressure.
Hutch
It will be hard to see on a logger Hutch, thats because at high RPM,s the pump delivers ample oil, I suppose the pressure reading is taken at the plug on the side of the case, so there is ample oil there to. The manual valve is a bottle neck, and most cast iron valvebodys have a horrible third gear circuit. The leak is downstream and wont show up on the logger.Have not seen that on the data logger , pressure seems pretty constant through the entire rpm range. What RPM do you see the check capsules become unseated Steve?
Hutch
Now think out of the box, Measure the surface that the ball seats on in square inches. multiply that by line pressure and this is the force that holds the ball on the seat, now spin that drum and that ball becomes awful heavy, too heavy to stay seated, if you could take a reading on the in the drum you would see the leak.
I didn't see this problem until I got involved with a car that ran in the low six second range, Two problems showed up, The high clutches were dragging in low gear so bad the driver could feel the drag by the seat of his pants in spite of his 3000 HP engine.
Cured that, but was still nipping the clutches on the shift, removed the ball, plugged the hole, and end of clutch problem.
You got to remember when the trans brake is applied the high gear clutch is applied and the piston is full of oil and "under pressure", its not residue you have to deal with, its real oil. The ball is seated at this point and offers nothing as far as any help.Very good stuff really enjoy reading this! I also have heard that with higher RPMs some transmissions have been known to have clutch apply through Centrifuging residue fluid left behind the apply piston by residue fluid being thrown against the inside walls of the inner drum piston area thus pushing the piston partially applying the clutches? It would seem that the 1/16" hole drill in the drum and the heavier return springs should resolve any issues with this when a trans-brake valve body is installed. Burt
What do you mean "don;t care who's vb you use". Compare a valve body to a cylinder head. only one flows air and the other flows oil.Most important note in the info griner posted is the "if it releases at all with a transbrake" the high drum goes from being clamped, to 6000 rpm in a split second, there is little time for the drum to exhaust, especially if just the ball and VB are doing the work...and outboard exhaust hole is always a critical item for fast/clean TB use - don;t care who's vb you use. That is just my advice.
As for the ball unseating at high rpm, I could follow that theory possibly. I would say it just make good sense to block the ball in pure racing application, not much to loose and might learn something, let you know.
