I just picked up a 1999 Gulfstream Tourmaster diesel pusher. It has a Cummins with the 6 speed Allison. The issue is, about half the time the engine is started, the shift indicator displays "*" and it will not shift into any gear. I can shut it off and restart it with the auxiliary start button pressed and it displays "N" and operates normally.
I thought maybe low voltage could be affecting the trans computer. All batteries are new, (house and engine), and the 4 engine batteries tested at over 1000 amps each.
I'm new to the motor home stuff and am just starting to research this, but thought I could get some insight here. Thanks in advance!
