If I go 8.75 in my car how much more hp will I need to go 8.65 with everything the same. Also how much hp do ya think it takes to go 8.60's. Thanks
So would it be safe to say it takes about 50 hp to gain every tenth at 3350lbs or does the hp requirement go up as et gets lower. Thanks againI think you'll need 50 hp over what you have now Bruce to run bottom 60 in the heat... that number might be a touch high, but better to be on the other side...
