Do it yourself
. You can make a homemade toe in deal and Speedway has a budget caster/camber gauge. Then you can align other peoples stuff for some extra $$. Trust me it's easy. If you can setup a 4 link you can do an alignment.
DOH!!!!You don't need that digital stuff. You can make your own turning plates and use a protractor. Remeber when the teacher told us in Math class to listen.
:smt023Do it yourself. You can make a homemade toe in deal and Speedway has a budget caster/camber gauge. Then you can align other peoples stuff for some extra $$. Trust me it's easy. If you can setup a 4 link you can do an alignment.
to take a caster sweep,it reads thru the rangeok whats the purpose of the turning plates and how is it done without them. john
