i have an aje crossmember form my fox mustang do i need to use a poly mount inbetween then trans and crossmember or dose the crossmember get bolted right to the trans, it looks like the crossmember would bolt right up to it and would it be good to run a solid mounted trans when i have solid motor mounts also
