1 - 5 of 5 Posts
I am work on a 331 f1r set up with air to water intercooler and was wounding were the best place to install AIT is should I put it before the t-body or put in the 1' spacer under the intake elbow..
Thanks for your help..Jeff
My Own Worst Enemy
I have mine in my intake elbow just before it goes into the spacer.
Thanks for the info so there is no real def if you put it in the pipe before TB or in the elbow...do you want to know the temp inside the intake not the intercooler pipie...Thanks jeff
just ahead of the TB is normal. The exception to this is if the ECM make specify it to be somewhere else. typicall the intake manifold will heat soak the sensor and create for some abnormally high readings.
1 - 5 of 5 Posts
