Pulling 6 from what 32,34.36 ???Oldhead(32 all the time and 12.0 to 12.5 with C16)I pull 2 degrees for 30 pounds of boost . But I have good fuel and because I run a timing chain with a regular distributor and no crank trigger you can probably factor that another 4 degrees comes out for chain and gear slack . So probably 6 total .
You are doing it old school Vinny !! I like your style !!
But, but, Steve, everyone says you should need to pull a bunch of timing on a boosted motor...:-KFCI run 36 degrees out the back door, 35 PSI 13.0 AFR Q16 110 degrees.
That should get ya talking![]()
I pull that from 40 degrees of timing .Pulling 6 from what 32,34.36 ???Oldhead(32 all the time and 12.0 to 12.5 with C16)
Yep, reading plugs and a lot of dyno testing at Steves . Truth be told we ran it a high as 42 degrees on the dyno but opted for safety over a little extra power .Vader, did you come up with this by reading the plugs?
No pump fuel changes things imop. You have to look at boost as raising cylinder pressure which essentially is like raising compression . If you had race fuel and inlet temps that are decent than yes you could leave full timing in likely. But on pump fuel that may not be consistent pump to pump I would read the plugs and add a little safety with a bit of timing knocked out . JMOPSo would this mean that with an air to air intercooler and only 10 pounds of boost no timing should be pulled? It will run on 93 octane.
I know howI run 36 degrees out the back door, 35 PSI 13.0 AFR Q16 110 degrees.
