Anyone good with air compressors / air systems ?
I'm racking my brain here ,I have a Craftsman 150 PSI 2cyl,7HP 60 Gallon tank compressor .It's hooked up to a Devilbis HAR602 Air control regulator .Same set up I had in NY BUT I changed one thing .I set everything up in the shop down here .The compressor is hooked up to the regulator with a 1/2 hydraulic line.I had a 3/8 line on it before .Air line hooked up to tools .When I hit the tool to operate the pressure drops like down to 10 psi.I opend up the regulator , I thought there might be a ruptured diaphragm but no.Everything seemed fine.I didn't take the canister apart though.
Could the 1/2 line be too much of a pressure drop?
I'm gonna try changing back to 3/8 line if that don't work I have a China Freight air
regulator I may try .Compressor works fine .
