1 - 17 of 17 Posts
www.ULTRA-CARBON.com
Just purchased an aluminum block 400 motor this week. Comes with the AFR 215 raised runner head. Since I don't see these heads on the AFR website, I am assuming these are an old casting? Maybe something that was a predecessor to the newer 227s? The engine is currently set up to run a 250+ shot of nitrous, but I would like to change cams and use it as a N/A combo. It managed 8.50s on a 250 shot at 2800 pounds.
The plan is to eventually get into the low 9s N/A, but I would be happy to be mid 9s N/A with a cam swap. Would this even be possible with these heads? Obviously going with newer heads or 12-18 degree heads would get me there, but what is the potential of these heads before I start changing pistons, intake and everything else associated with a top end upgrade?
The motor description from the ad: Rodeck Aluminum SBC, 401cid, J&E 14.6 to 1, Total seal rings, Cola 3.75” Crank, std. /std. Manley Super 70 Aluminum rods ARB 2000 bolts, O-ringed, AFR 215 raised runner, Jessel Shaft rockers, Manley Nextex, Brodix HV1 intake, Wilson 1 spacer, Barry Grant silver claw 1000cfm,Tilton Starter, B&M flexplate, MSD Dist., Wires, Crank Trigger, Stef’s oil pan for chassis car
The car: 3140 pounds with iron block SBC, me in it, fueled up and racing, TH350, 5400 Coan converter, 4.56 geared 9-inch, footbrake launches at 2200rpm
Thanks in advance.
i had a set thta were ported heavily and rolled over to 21* in early 2001 or so that went 350int-245exh at 700 lift so they definetley move some air
that head is plenty enough to run DEEP in the nines on motor alone
CFH
FWIW, I remember reading an article about a heavily worked set of RR215's from Joe Sherman, flowing about the same as the new 235's. Im not positive but, I think the sheetmetal dual carb 14 to 1 406 they tested made over 700 with both heads?
they stopped making that head when the Eliminator series was introduced . and as stated Joe Sherman has made some good hp with those heads i,m sure a few others have as well .
a non raised runner standard intake port location head wont hold a candle to those;)
Discussion Starter · #7 ·
Ok, sounds like these heads aren't as anemic and outdated as I thought. After running mid-10s with a set of new 210 AFR Eliminators on a similar sized engine, I figured a 215 older style head wasn't going to be much better. I'm glad it sounds like I am wrong in that assumption.
So, given the car and engine specs in my first post, what sort of roller cam should I be looking at getting to get the maximum effort out of this combo without changing anything else? I would appreciate a suggestion for both 1.5 and a 1.6 rockers as I am not sure which size Jesel shaft rockers are on the motor.
Thanks in advance, once again.
talk with Bullet Cams give them all the details you can , same when it comes to matching a convertor
PHR did a 392 build using those heads when they came out.670hp at over 7 grand.put it in a stock suspension 69 camaro with drag radials and a powerglide and it went bottom tens if i can recollect.was approx 12 yrs ago.
i remember that write up i think i have it somewhere
Discussion Starter · #12 · (Edited)
I'd appreciate it if you could find the write-up for that Mikey. Otherwise, I'll try to look it up online and see what they did and what cam they used. 670hp should get me to a mid 9 pass in my car. My goal is 650hp so that I am at least solidly in the 9s and competitive in NPSA Hot Street. I don't expect this motor to win me any races outright, but to at least be within a few tenths of the competition would be nice. My torque converter is good. It was made for almost exactly what this combination will run if it makes 650hp.
I have these heads also. Seem to be a pretty good head. I'm trying them out on a 400ci procharger setup. I hope they are going to work out good on it when I get the tune better. For a 23 degree head they are nice I think but with new technology everything usually goes away for something new.
Discussion Starter · #15 ·
Those heads CAN be very good in the right hands,, Joe Sherman did some 400 cui motors with them making over 800 hp N/A
Sounds like its unanimous that Joe Sherman is the guy to talk to on these heads. Is he on YB? Or can someone please give me his contact info? Did a search and found his name plenty of times, but no contact info.
i,ll dig thru my collection and see if i still have that issue
1 - 17 of 17 Posts
