1 - 20 of 47 Posts
I have (4) of these pumps on engines, one just completely locked up, other 3 are all older and probably right behind it. I always drain the tank after the race and put some oil in the pump when the lines off to lubricate it.
I called aerospace and they want to sell me a rebuild kit for $115, I only wanted the vanes, they said they will sell me 3 vanes for $99!, Wow.
Anyone know of a cheaper replacement vane for the pumps, all are 3 vane pumps. I am told they are Kevlar, wondering if something made out of nylon, Teflon would last longer?
A friend of mine just had his lock up. The vanes were fine but when he got it apart it was the bearings causing the problem.
I forgot to add it may be Vesconite material for the vanes.
EFI/N2O JUNKIE
They are pretty to look at though aren't they.......... I went with Star, yeah, very blah looking, not cheap, but has been bulletproof! OK, gotta spray a can of brakeclean though it every 50-75 passes when I change my oil, no big deal, a few thousand passes and it is still perfect, but not pretty...........
Seems like they all like synthetic oil. I always prime mine when it’s been sitting for a while. Lots of street miles @50% on my GZ. I’m following this thread for an answer.
Premium Member
I've been running the large GZ Motorsports vacuum pump for a couple of years now on the streets, it only gets a small amount of oil mist for lubrication and is still working fine.
Discussion Starter #9
All the pumps are about the same cost wise aren't they?. I've only seen one other pump lock up on a car my son was driving, and it was a moroso. I've had good luck with the 4 that I own up to now.
Upon disassembly, I did notice that the bearings were shot on front and back due to the housing bore being undersize causing a lot of "crush" to the bearing, they were not easy to get out, must have been a hard fit when they assembled it at 4:30 on a Friday!
I think the bearing problem is what locked it up and not the vanes as I originally thought.
How much press fit did it have?
Discussion Starter #11
I could not measure it when it was factory assembled. Considering the amount of effort it took to remove the bearings, I am guessing a lot, I had to take out .0015 to remove the score marks and get the hole round again, the aluminum bore is much softer than a bearing. Now it has about .0002 press fit. When I put new bearings in with the vane holder and assembled without vanes it spins much nicer, should last much longer now.
I also don't run much belt tension at all, there is no actual load on the pulley so no need to run it tight like an alternator. I was told by aerospace that less tension will increase bearing wear..... So will less bearing interference.
Gotcha, it does sound pretty darn tight. Arbor press put it right in the hole. LOL I like running the cog belts so there is no tension at all. Can you even get that type of sheave for Moroso or Aerospace?
The Liquor Makes Me Think
I wonder if teflon or delrin would work. Both are tough, self lubing and oil resistant.
You based your purchasing decision strictly on price.
And you know this how? Maybe he thought it was a much better looking vac pump than yours and thats why he went with it. I know that's what I did.
Yea, you're right. Inexpensive AND shiny. The two best reasons to choose a performance component.
You got 2 out of the 3. It also does what it's suppose to do just fine. 🤔
EFI/N2O JUNKIE
This Steve? Whomever it is, you're cracking me up!
I have put thousands of passes on my Star setup. Have it all. Mandrel, separator tank, sportsman pump, relief valve, valve cover fitting. If I ever get the coin together I will put the same exact setup on my wives mid 10 second ride, the stuff works! I did it for two reasons, the main being to help stop oil leaks! The second was for my heavy nitrous days.
Dang Mike, how many do you have? I can see why you would have to save up. LOL
1 - 20 of 47 Posts
