1 - 7 of 7 Posts
Banned
Where is the Master cylinder? Yes, if it's at or below the calliper's.
X2
At or below the height of the calipers you should run one at both ends.
Discussion Starter · #4 ·
Fox body Mustang. The master cylinder is well above the calipers. I thought someone at Aerospace told me I would need the 2# valves for the rear brakes. Just couldn't remember why they would say that? Thanks for the help guys!
If your master cylinder is in the stock location, you will not need any valves....
Finally talked to Aerospace today and they recommend 2# valves for the front and rear on all applications for insurance.
Some guys have trouble with the Aerospace brakes taking a pump or two before they get good pedal because the calipers really pull back the pistons. I'd say the 2# valves help keep the pistons closer to the rotor so you don't have to pump to get a good pedal. I don't have any issues with mine. I think it's partially in the way some people bleed them.
1 - 7 of 7 Posts
