1 - 5 of 5 Posts
Does anyone on here run the aerospace components 2 piston floater style front caliper setup? I'm running into some issues with the pistons not retracting into the bores.
100473
Installed their front kit on my 68 last year. So far so good. I did have to grind down a couple high spots on the caliper to clear my 4" weld wheels due to the offset.
Sent from my SM-G965U using Tapatalk
Did you use the 2 piston floater caliper, or the fixed position 4 piston calipers?
1 - 5 of 5 Posts
