1 - 9 of 9 Posts
Does anyone have solid feedback from the Aeromotive brushless 7.0 gpm pump. Looks like the cats ass, but haven't found much feedback through my searches. My application is fuel injected turbo motor on e85. The 5.0 will be just shy of what I need fuel wise, and dont have room for a mechanical setup.
I’ve been running the TVS 5.0 on the street with gas. Bad ass pump! If you need the 7 I would just step up to the 10 Incase you decide to run methanol or turn the power up in the future.
I was considering going to the 10 like you said for room to grow In the future. It's still a possibility. Glad to hear that you put it through the paces on the street and it's still kicking.
Built a twin turbo ctsv running 176 in the 1/4 at 4K lbs on e98 on the 7.0 pump. Rock solid fuel pressure. Has seen quite a bit of street time as well.
what hp is it rated with methanol ?
Depends on what type of power adder, N/A, carb, or fuel injected. Turbo fuel injected ~ 13-1500hp.
  • Fuel injected engines:
    up to 3400 FWHP – naturally aspirated
    up to 2600 FWHP – forced air induction
  • Carbureted engines:
    Up to 3600 FWHP – naturally aspirated
    Up to 2700 FWHP – forced air induction
This is on gas. Usually the rating is cut in 1/2 for methanol.
1 - 9 of 9 Posts
