1 - 9 of 9 Posts
heard about that stuff years ago ,,They said that 1/8 of an inch used as insulation in a house and you could heat the house with a candle.
Can you imagine how many jobs would be lost if they used it to insulate houses???
That's a pretty substantial exaggeration. LOL
I use it every day and I can assure you it's not quite that good.
We order it in 10mm thick rolls....6 layers used on vessels averaging 900* will let very little heat out. The outer jacketing will feel cool to the touch.
The stuff used to be miserable to work with but they have a silicone coating added now that really cuts down on the dust.
As far as insulation goes its as good as it gets...many large refineries I work in are starting to specify its use anywhere possible.
My company makes a proprietary coke drum insulation system. In the past we made these using mineral wool 6" thick using 8# density material.
We get better performance now with only 60mm. The benefits far outweigh the cost in our application.
A bunch of the AeroFoam is up on MARS.
JPL uses it to insolate the rovers, bitchen stuff but the "Foam" version is ultra fragile and almost lighter then air
Thinking about Cars now, but could Aerogel replace Dynamat?
1 - 9 of 9 Posts
