1 - 4 of 4 Posts
532 bbc with a 106, have a new cam on the shelf that is real close to what Comp Cams said I need but the centerline is 112. would advancing it a couple of degrees help it out.
With a 532 and a single 106 , I'd retard that!;) you could run naturally aspirated cam and still spool the turbo.
Hope you have a g trim / 1.5 housing
^^^X2^^^^ Definitely wouldn't advance it any and run a minimum of 1.5A/R turbine housing. A 2.0 housing would be even better.
you need a bigger turbo truth be told, I wouldn't advance it, as others have already said, you need a bigger hotside.
1 - 4 of 4 Posts
