1 - 4 of 4 Posts
I set mine so the adjustment bolt just touches the pump arm, with no pressure on the diaphragm.
Hold the throttle wide open,push the acc pump arm down with a screwdriver , adjust the screw to about 13-15 thousandths.
^^^^^^ X2.... 425ci has it right. We even recheck for a little clearance every time we have the bowls off, otherwise you won't get full stroke on the accelerator pump.
1 - 4 of 4 Posts
