1 - 20 of 45 Posts
· Registered
How many watts does the average small ac window unit use. I have a 700 watt continues- 1800 peak invertor 12volt to 110 and Im trying to figure out if it will run it.
· Registered
there should be something on the unit telling you it's input and output.
· Registered
about 6000 BTU's is all you are going to be able to run on 700 Watts. Carrier makes an inexpensive "Window Shaker" that runs on 115V AC and 600 watts. Good for about a 200/250 Sq ft room.
KCA061P
· Registered
Discussion Starter · #7 ·
sweet then sounds like the average window unit one will work, Im installing it in my Ford Van for the long ride to Orlando so it should be plenty to cool it down inside.
· Registered
· The Enemy
More than likely, if the inverter has overload/reset it will trip the overlod on start-up (when compessor hits) and it won't even let it run.
After screwing his friends out of gas money for towing him and his truck to orlando last year i guess they all said no to him this year.
Now hes stuck with the genius idea of putting an AC unit in a ford econoline van. :smt043
· Registered
Discussion Starter · #19 ·
Just got back from ABC ware house bought the cheapest one they had pluged it into the dervertor and bam cold air. I turned it off and on several times so far the only thing it does is blow cold air. Now I gotta get the sazaw out for some custom fitting.
1 - 20 of 45 Posts
