1 - 5 of 5 Posts
I am curious if anyone has put a A1000 regulator on a Magnafuel log. I ask as I want to run a holley reg for NOS and a A1000 for the carb but the return is out the bottom of the reg, typically where the inlet is.
Looking for options
I will be running a return through the A1000 regulator back to the tank, no deadhead.
Vendor
I had the A1000 4 port regulator before and ran 2 fuel pumps though and used the A1000 for just the carb so I didn't have that problem. This year I am running just their Eliminator pump and an A2000 pump with their modular regulators. The A2000 is just for regulating the high side of the pressure and the 3 modular regs will be used for the 2 nitrous systems and 1 for the carb. The fuel goes in the left side of picture and out the bottom of the A2000. Just an idea.
Thats a nice setup, I was trying to figure out a clean way to run an A1000 reg for carb and a Holley for NOS on a fuel log.
1 - 5 of 5 Posts
