1 - 6 of 6 Posts
The car is a BBC turbochaged. The trans is a glide built by a guy I no longer speak to ( for a differant reson) anyway when I prespool into the lights foot braking it then hit the transbrake button the car trys to hold but the more boost I build the more it rolls. Until it pushs out of the lights. I've played with it in my shop,and if I take all the boost away it will not move ,only under boost is the a something to adj in the trans that will fix this. All aftermarket goodys in the trans, and it's BTE t/b and v/b
from across the pond...
Depends on the power,but i'd like to see 225psi. Also check the transbrake spool valve is indexed correctly and reverse circuit also needs to be verified pressure wise. It must have the same pressure as forward.
The port at the back right hand side of the trans for rev.The servo port for low/high.
The cooler ports are converter pressure and not what we're looking for in this case..
1 - 6 of 6 Posts
