Okay I just finished putting a carb swap on an 89 mustang
motor was just freshened new bearing rings etc.
302 cu inches
9.5 to 1 compression
heads are twisted wedge 2.02 intake mildly ported
vic jr. intake mildly ported
.513 lift cam hyd roller
108 lope sep
Pro System 650 carb
manual trans
MSD dist locked advance
before the carb swap the car made a few hp under 300 at the tires on the dyno with a smaller E cam
#1 - Im having a problem getting the idle down on the carb
I would like to get it around 800-900 rpms but every time I turn the idle screws down the car will not stay running at that rpm it just kind of dies out
so Im having a bit of an issue there
#2 - The car gets a bad stumble off of idle Ive played with the carb linkage and everything is where it should be Ive played with the idle screws and adjusted the floats I cant seem to get rid of it,
i know Im probably gonna have to do possibly a squirter change air bleed change jet change or all of the above I just dont know what direction I should be going in up or down with the changes
#3 - Im getting fuel pressure creep sometimes it will creep up to almost 12 lbs and stay up there
fuel system is a magnafuel quickstar 275 pump, filter before pump,
return line from the pump to the tank - 6
feed line -8
regulator is magnafuel 2 port regulator
everything in the fuel system is brand new,
and its getting fed from a stock tank with a sump
any advice is greatly appreciated Ive been playing around with this thing for about 2 days now with no success
timing is locked at 32 deg total timing,
This carb was not built for this motor it was built for something a little more higher hp than what I got but I still think I should be able to get it to work on the motor I have
thanks for any help you can lend
302 cu inches
108 lope sep
Pro System 650 carb
manual trans
feed line -8
